Alternate way to change properties of board file.
972 次查看
rutuja_patil
I am working on imx8m mini. I have to use ECSPI2 on J1003 expansion header. I am trying to find out  board file for imx8m mini after kernel integration for spidev configuration. I found files for imx6, 7 but I am not able to find board-imx8mmvek.h.
1 回复
900 次查看
Hi Rutuja
for ecspi2 spidev one can look at boundary devices example imx8mm-nitrogen8mm.dts :
linux-imx6/imx8mm-nitrogen8mm.dts at boundary-imx_4.14.x_2.0.0_ga · boundarydevices/linux-imx6 · Git...
linux-imx6/imx8mmn-nitrogen8mm.dtsi at boundary-imx_4.14.x_2.0.0_ga · boundarydevices/linux-imx6 · G...
