Hi all,
I am adding Unix Bench recipes to Yocto and its successfully added. Now the problem is while executing ./RUN command on imx6 Board (Kernel version : 3.14.28) I get POSIX.pm error as follows :
root@iWave-G15M:/usr/src/unixbench-5.1.2# ./Run
Can't locate POSIX.pm in @INC (you may need to install the POSIX module) (@INC contains: /etc/perl /usr/lib/perl/site_perl/5.20.0/ /us.
BEGIN failed--compilation aborted at ./Run line 7.
In my PC POSIX.pm is available in location : /usr/lib/perl/5.14.2/POSIX.pm ,But in yocto rootfs perl is available but could not find POSIX.pm.
Please provide me the details about How I can POSIX module in yocto ? or any other solution to this problem.
Thank you all
Hello
I have exactly same problem, did you find any solution for installing Unix Bench?
