Add alexa in imx8ulp-evk9
985件の閲覧回数
dhruvinrajpura
I am using imx8ulp-evk9 and want to add alexa support in it, Can anyone tell me what I need to do for that?
タグ(1)
8 返答(返信)
959件の閲覧回数
Chavira
Hi @dhruvinrajpura!
Thank you for contacting NXP regarding the Amazon Music SDK. Unfortunately NXP stopped the internal development of this SDK in 2020, and the SDK from 2020 is no longer suitable for distribution.
We now work with partner StreamUnlimited  who provide a range audio solutions including streaming and multi-room for NXP processors, compatible with the latest specifications.
Best Regards!
Chavira
939件の閲覧回数
dhruvinrajpura
Hi @Chavira
Thanks For answer, I taken look at sreamunlimited found interesting, I am planning to use stream1955 with my imx8ulp, what I need to do to integrate in yocto?
926件の閲覧回数
Chavira
Hi @dhruvinrajpura!
The stream1955 is a board based in iMX8MM, streamunlimited should be based in our Yocto Project to do their proper sdk but I am not sure if they provide their Yocto Project for their customers.
To get more information about that board please contact to their support.
Best Regards!
Chavira
924件の閲覧回数
dhruvinrajpura
Thanks @Chavira  For Reply
Got point, Just required your suggestion that if I want to integrate device like alexa with imx8ulp which device you will suggest that can best fit for that?
917件の閲覧回数
Chavira
Hi @dhruvinrajpura!
The product that you can use is the Stream1955 our partner offers a strong sdk for any audio use cases.
You can use Alexa sdk with the mentioned board according to the documentation of StreamSDK.
Best Regards!
Chavira
879件の閲覧回数
dhruvinrajpura
Hi @Chavira
Thanks for reply
I checked that in build of imx8ulp there is nothing like stream/streamunlimited is there in menuconfig and I don't found any type of proper documentation here(https://www.streamunlimited.com/stream-sdk/), before purchase I want to check compatibility , Can you help me with this?
872件の閲覧回数
Chavira
Hi @dhruvinrajpura!
I think the sdk should be compatible wit the iMX8ULP since the sdk runs in Linux.
To be sure you have to get contact with streamunlimited support.
You can send an email according to your region too.
Best Regards!
Chavira
859件の閲覧回数
dhruvinrajpura
Thanks @Chavira
Actually I found this interspersing, but I want solution on IMX8ULP directly that is interactive audio solution or searching if it has any inbuilt with it
