Active Faults in IMXRT1050 Hard Fault (HFSR) and Usage Fault (UFSR)
Shashi_ranjan_14
How to Solve this Hard Fault (HFSR) and Usage Fault (UFSR) faults in the MCUXpresso and imxrt1050.
I am using an embedded wizard-generated GUI. Merage with auto generated code of Simulink . After executing these hard faults (HFSR) and usage faults (UFSR), faults came.
How do I solve this problem?
@nxp4 @IMXRT1050 @nxp
jingpan
Hi @Shashi_ranjan_14 ,
There is a call stack window in MCUXpresso which can show where is the hardfault comes from. You must find the root cause of the problem. No other special method.
Jing
