Activate the option for menuconfig -imx6dual lite
shankovai
Hello  support team,
MACHINE=imx6qdlsabresd DISTRO=fsl-imx-wayland source ./imx-setup-release.sh -b build
bitbake imx-image-full
1. List out the Options needs to be activated for the i.mx6DualLite processor in Menuconfig
Kindly provide me the documentation with snapshots
2. menconfing will be available after the image has been created. so when i do any changes in the configuration do i need re-build the image again bitbake imx-image-full . please confirm
kindly provide me documentation
thanks
joanxie
depends on what images do you need, if you just need kernel images, you don't need bitbake full anymore, after you rebuilt full images, you can get new wic file, you can try it and check the images generate data to double confirm
joanxie
