Accessing ADB and UART console in production image
namanthaker
I have built and flashed production image (i.e. user image) on IMX8MM EVK device and I am unable to access the ADB or UART console shell.
I want to access the ADB/UART console on the device for debugging.
Along with ADB/console access, I also need to use 'su' command enabled to access the kmsg and sysfs/rootfs.
What are changes required in the AOSP to enable ADB and UART with 'su' access by default in the production image ?
Naman
AldoG
Unfortunately I believe this may not be possible, since for ADB root access you'll need to build using userdubg type, this should provide image with root access for debugging
Aldo.
