About the frequency of DRAM_SDCLK
已解决
跳至解决方案
2,165 次查看
goto11
Hello,Community
The DRAM Clock Structure is shown in Fig 5-7 of the iMX7D reference manual.
Is the phy_clk the clock (DRAM_SDCLK) supplied to the DDR memory?
best regards
Goto
标签 (1)
1 解答
2,128 次查看
goto11
Hello,Community
Where is the set frequency reflected as the frequency of the clock (DRAM_SDCLK) supplied to the DDR memory?
best regards
Goto
在原帖中查看解决方案
6 回复数
2,157 次查看
Hi Goto
not. phy_clk is clock supplied to DDR PHY (DDRP) module described
in sect.9.3  i.MX 7Dual Applications Processor Reference Manual
2,149 次查看
goto11
Hello,Community
thank you for your answer.
Correct the question.
Is phy_clk the same frequency as the clock (DRAM_SDCLK) supplied to the DDR memory?
Goto
2,145 次查看
Hi Goto
no.
2,140 次查看
goto11
Hello,Community
The reference manual has the following description.
If not, where is the set frequency reflected as the frequency of the clock (DRAM_SDCLK) supplied to the DDR memory?
best regards
Goto
2,134 次查看
Hi Goto
this description is applied to clock for DDR controller and PHY, not for
clock supplied to the DDR memory.
no.
2,129 次查看
goto11
Hello,Community
best regards
Goto
