About the frequency of DRAM_SDCLK
Search instead for
Hello,Community
Which register setting value determines the frequency of the clock (DRAM_SDCLK) supplied to the DDR memory?
best regards
Goto
Could you tell us which product are you using? And which version BSP are you using?
It is MCIMX7SABER.
best regards
Goto
I'm using i.MX 7D.
best regards
Goto
Are you using the i.MX7D or 7S?
I'm using i.MX 7D.
best regards
Goto
You can see these SCG1_DDRCCR ,SCG1_APLLPFD in software code.
Where can I download the software code?
