Dear all,
I received the question about MLB from my customer.
In my understanding, only the product of the automotive grade is supporting MLB.
However, in i.MX 6Solo/6DualLite datasheet for Consumer Products, these are described as one of the functions of all devices.
⇒ http://cache.nxp.com/files/32bit/doc/data_sheet/IMX6SDLCEC.pdf#page=3
Are these incorrect?
George
解決済! 解決策の投稿を見る。
Please use part number coding (part differentiator field) to define
what parts support the MLB. Please look at Figure 1 (Part Number
Nomenclature) of the i.MX6 Datasheets. Say, number 7 for i.MX6 D/Q
means :
“Industrial – w/ VPU, GPU, no MLB”.
The i.MX6 Series Datasheets :
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6DQIEC.pdf
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6DQCEC.pdf
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6DQAEC.pdf
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6SDLIEC.pdf
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6SDLCEC.pdf
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6SDLAEC.pdf
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6SLCEC.pdf
Yuri
Dear Yuri,
That is, are Example Orderable Part Numbers Options field in Table-1 wrong?
=> http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6SDLCEC.pdf
George
The Table 1 is not fully correct.
Yuri.
