About setting of the EIM timing.
Search instead for
tomo
Now I considering EIM timing parameter to set to WCSA=2, WEA=1 for asynchronous memory access.
Does i.MX6D accept this setting and properly work ?
Yuri
  generally it is possible to set to WCSA=2, WEA=1 for EIM asynchronous memory access,
but exact configuration depends on application. Use specs of the device, connected to the EIM.
Yuri.
Yuri
Yuri.
