Dear all,
I am referring to IOMUXC_GPR3 register.
IMX6SDLRM.pdf (Rev1)
- IOMUXC_GPR3 field descriptions(P.2039)
In 13-15 fileds, "global acknowledge" and "debug acknowledge" are described.
However, I cannot find these detail descriptions.
Would you teach the part where these are indicated?
Should these bits be set in what kind of case?
Hi yuuki,
these are arm CTI signals (described in Chapter 10 Debug
DDI0388I_ cortex_a9_r4p1_trm.pdf document (www.arm.com) ) -
can be masked separately for each core.
Shortly IMX6SDLRM.pdf (Rev1) describes them in sect.12.6 :
The Cross Trigger Interface (CTI) is included in the
Cortex-A9 platform to provide a common programming model for use by the debug
tools, control the trigger sources, and interface to the Cross Trigger Matrix (CTM). The
debug is controlled via an ARM Debug Access Port (DAP).
chip
