- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report Inappropriate Content
Hi All,
When ON the LDO (LDO_ARM, LDO_SOC, etc) in i.MX6DQ, the inrush current flows because the rising-up of LDO is precipitous.
So, we'd like to decrease the inrush current.
Could you tell me the way of loosen the steep LDO output in i.MX6DQ?
Keita
Solved! Go to Solution.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Keita
at power-up time (when processor is not fully powered yet) there is
no method to set the slope of LDO output inside i.MX6DQ.
After powering processor, PMU_MISC2n REGx_STEP_TIME bits define ldo timings,
that is when LDO changes one voltage to other, voltage changes with
steps defined in REGx_STEP_TIME .
During processor power - up (that is meaning of LDO "inrush current") - REGx_STEP_TIME
is not used.
Unfortunately there is
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
Hi Keita
is not used.
