About imx6 picture rolling problem.
Search instead for
guanliangding
Hi, all:
     We use the schemes of adv7282m->imx6 be a multi channel camera system. But, when we switch the channel. the picture rolling a few time, and then stable. What should we do to solve this issue? I guess it must be cause of last picture not ending correctly.
Tags (4)
weidong_sun
Hello ding,
    After you switch channel, you should reset CSI IP module of CPU , then the issue should be resolved.
Weidong
guanliangding
Hi weidong:
     Thanks!
     What is the "CSI IP module", it is ipu csi or csi2 controller?
