hello,Community
About the mx7d_12x12_1p8v_lpddr3.ibs file
I confirmed that there is a drive strength selection signal such as “PBLPDDR3_DDS_240ohm“ drv000 ”” in the LPDDR3 selection signal.
However, there is no On-die-termination (ODT) resistor value selection signal.
What should I refer to?
best regards
Goto
Solved! Go to Solution.
use chapter 6 (IBIS model) of the Development Guide.
http://www.nxp.com/files/32bit/doc/user_guide/IMX7DSHDG.pdf
Yuri
Yuri
