Do I need to reflect the results of calibration in the script file and download it again before the stress test?
Or should I run Stress Test without changing the Script file after Calibration?
Goto
Solved! Go to Solution.
Hello Goto,
I would recommend running the stress test after loading the values obtained from the calibration. This way you can results on the stress test closer to what you would expect on the field.
I hope this helps!
Hello Goto,
I hope this helps!
