About desk clock alarm wake up from sleep mode(imx6q with android 5.0)
yenchao
Hi all,
I'm working on imx6q with android 5.0.
We have met a problem with using desk clock alarm to wake up from sleep mode.
Sometimes it works fine, but sometimes it can't wake up,
espically when the alarm time is far from current time.
It seems like there are some problems in rescheduleKernelAlarmsLocked(AlarmManagerService.java).
We have tested this issue on boundary devices BD-SL-i.MX6.
It has the same problem.
Does any one know how to fix this issue?
Any advice or suggestions will be greatly appreciated!!
Thx
Yen
Labels (3)
yenchao
Hi Carlos,
I have tried the patch
but it failed
and showed error message as below
Applying: Revert "ENGR00300018-1 Update USB and Power Manager driver for android linux kernel 3.10"
error: include/linux/wakelock.h: does not exist in index
error: kernel/power/main.c: does not exist in index
error: kernel/power/suspend.c: does not exist in index
error: kernel/power/wakelock.c: does not exist in index
Patch failed at 0001 Revert "ENGR00300018-1 Update USB and Power Manager driver for android linux kernel 3.10"
The copy of the patch that failed is found in:
   /media/yenchao/334fef4a-f0d4-41f6-98f4-761d950fcd8a/yenchao/work/i-mx6-android-5-0-0_1-0-0/test/.git/rebase-apply/patch
When you have resolved this problem, run "git am --continue".
If you prefer to skip this patch, run "git am --skip" instead.
To restore the original branch and stop patching, run "git am --abort".
Could you advise me how to apply the patch
Thx
Yen
CarlosCasillas
It seems the conflict of kernel version.
Can you tell me which standard GA release are you using?
Best regards!
yenchao
Hi Carlos,
I have applied the patch file to the android 5.0 project successfully.
But it can't go into sleep mode now.
It just only close the screen, but when I touch the mouse, it will open the screen.
Is this the correct behavior?
Thx
Yen
CarlosCasillas
Hi Yen,
Have you tested it on SABRE SD or SABRE AI boards?
Could you please provide the steps to reproduce it?
Best regards!
/Carlos
yenchao
Hi Carlos,
We just only tested it on boundary devices board.
(we don't have SABRE SD or SABRE AI )
1.open clock app and set an alarm after 12 hours than now.
2.sometimes it won't wake up.
Thx
Yen
CarlosCasillas
Hi Yen,
AE team commented that it is a bug, and they already prepare a patch for this.
Please try the patch in the attachment.
Hope this will be useful for you.
Best regards!
/Carlos
yenchao
Hi Carlos,
I have applied the patch file to the android 5.0 project.
Thx
Yen
CarlosCasillas
Hi Yen,
We are internally reviewing your case.
I will post an update as soon as having news.
Best regards!
/Carlos
