About capacitor value for some power supply in i.MX6
Search instead for
tomo
Hello, all.
SABRE-SD board has 22uF capacitor for VDD_HIGH_CAP, NVCC_PLL_OUT pin.
But these pin are recommended a 10uF capacitor according to Design Checklist (IMX6DQ6SDLHDG_Rev1.pdf).
And it is written in checklist that operation cannot be guaranteed, if capacitance over 10uF.
Why SABRE-SD board has 22uF, and does SABRE-SD board not occurred problem so far?
Tomo
Hi Tomo
to guarantee operation in whole temperature range
and production process variations it is necessary to
follow recommendations Design Checklist IMX6DQ6SDLHDG_Rev1.pdf.
Also SABRE-SD board design was developed before all processor
documentation was prepared.
tomo
My customer pointed out to me that 24 MHz crystal has stop once before stable oscillation.
I changed to 22uF capacitor for NVCC_PLL_OUT pin, then 24 MHz oscillation stop phenomenon is not occured.
Could you tell me if this phenomenon is related to the value of the capacitor?
Hi Tomo
