About a Wi-Fi module supported in AndroidL5.0 for i.MX6
3,976 次查看
yuuki
Senior Contributor II
Dear all,
AndroidKK4.4.x of i.MX6 supported a module of Atheros and Silex.
However, these are not listed in release note of AndoridL5.x.
Does AndoridL5.0 support a module of Atheros and Silex?
Yuuki
标签 (2)
标记 (3)
3,827 次查看
Hi Yuuki
L5.0.0 supports Silex, L5.1.1 not, refer to attached Release Notes
4 回复数
3,828 次查看
Hi Yuuki
3,827 次查看
yuuki
Dear Igor-san,
Thank you for your support.
Noted with thanks.
By the way, do you understand the reason not to support it in L5 .1.1?
Yuuki
3,827 次查看
Hi Yuuki
seems drivers are not available for L5.1.1,
since it uses more new kernel.
3,827 次查看
yuuki
Dear Igor-san,
Thank you.
I understand.
Yuuki
