About a SATA device detection error for i.MX537
已解决
跳至解决方案
1,672 次查看
yuuki
Senior Contributor II
Our customer reads the kernel image and rootfs of Linux from SATA.
Bootloader is booted from SD card.
Usually, Linux starts correctly.
However, it fails one out of ten times.
Error is "No port device detected!".
When an error occurs,
According to the log, a state seems to be 'phy not ready'.
I attach the log of an error and a normal operation.
I think that this is applied to errata "ENGcm11084-5."
However, a workaround of this errata is "None".
Is there any method of avoiding such an error by software?
May I have advice?
Original Attachment has been moved to: SATA_Comparison-of-operation.txt.zip
标签 (1)
标记 (3)
1 解答
1,450 次查看
jimmychan
Sorry, no workaround for this issue.
在原帖中查看解决方案
2 回复数
1,451 次查看
jimmychan
1,450 次查看
yuuki
Dear jimmychan,
Thank you for your support.
We consent to this matter.
