About UART1 of i.MX8M Mini
已解决
跳至解决方案
2,316 次查看
okamotosatoshi
Hi There,
I used 「MIMX8MM6CVTKZAA」.
The functions are different for the reference board, reference manual, and pin tool.
Which is correct?
(The reference board and the reference manual have the same function.)
- satoshi
标签 (1)
1 解答
2,311 次查看
Hi okamotosatoshi
in such case it is necessary to follow Reference Manual
Chapter 8 Chip IO and Pinmux
在原帖中查看解决方案
2 回复数
2,296 次查看
okamotosatoshi
Hi igor
Follow the reference manual.
I also expect improvements in the pin tool.
- satoshi
2,312 次查看
Hi okamotosatoshi
