Hi There,
I used 「MIMX8MM6CVTKZAA」.
The functions are different for the reference board, reference manual, and pin tool.
Which is correct?
(The reference board and the reference manual have the same function.)
- satoshi
Solved! Go to Solution.
Hi okamotosatoshi
in such case it is necessary to follow Reference Manual
Chapter 8 Chip IO and Pinmux
Hi igor
Follow the reference manual.
I also expect improvements in the pin tool.
- satoshi
Hi okamotosatoshi
