Hello community,
In errata of i.MX6 (IMX6DQCE), it have errata of useing SSI in i2s mode function.
It have a software workaround in Linux BSP release imx_3.10.1_1.1.0_ga.
I think that this commit applies.
ENGR00273838-4 ASoC: fsl: Enable dual-fifo mode as default
But newer version of Linux BSP have no implement about it.
Is this software workaround are integrated in newer version of Linux BSP?
Ishii.
Solved! Go to Solution.
The workaround should be already integrated into the later versions of the Linux BSP.
Artur
Artur
Hello Artur,
Thank you for your answer.
How about android BSP?
Our customer use Android N 7.1.2_2.0.0, it is Linux 4.9.17 kernel based on the Linux BSP L4.9.11 ga.
Is it integrated this workaround?
Ishii.
Hello art
I'm very sorry my stingy question.
Is it integrated to Android BSP?
Our customer use an Android BSP N7.1.2_2.0.0.
Ishii.
