About Non-Gated Clock Mode issue of the Parallel CSI module on the i.MX 6ULL series MPU.
已解决
跳至解决方案
4,394 次查看
vikenzhou
Hi, I am have a question about the Parallel CSI module, hope here can get answer, thank you!
When MPU is running  in Non-Gated Clock Mode, because the HSYNC signal will be ignored,
How know a line the number of pixels, it is possible using the clock edge to latched data;  if so,  in this Parallel_CSI_TX side, the pixel data of a line can many discontinuous clock cycles to send out ?
Please see below the figure,  thank you!
1 解答
4,388 次查看
joanxie
for non-gated mode, pls see the pic as below:
在原帖中查看解决方案
4 回复数
4,378 次查看
vikenzhou
Thans for your great support, the following questions please help guide again, thank you!
1, I have to see the pictures of you reply which is included a Data_EN signal, the signal in the Parallel_CSI_RX is necessary? The figure 19 on page758 of document  (IMX6ULLRM.pdf), Here is no use this Data_EN signal.
2, When sending a line of pixels, is the need for a continuous clock to send a line, or send a line of pixels can be discontinuous .
4,389 次查看
joanxie
4,366 次查看
vikenzhou
Why in rev.1 Reference Manual there is no Data_EN .
4,374 次查看
vikenzhou
