Hi There,
I want to check for IMX6.
Unused MIPI recommends "Leave unconnected".
Hardware Development Guide for i.MX 6DualPlus/6QuadPlus, 6Dual/6Quad and i.MX 6Solo/6DualLite Applications Processors
2.8 Unused analog interfaces
Is this due to shutting down the PHY?
We are considering whether termination is necessary when the camera is not in use.
Is it possible to terminate (for internal IMX6) MIPI CSI?
Do I have to terminate externally?
- satoshi
Solved! Go to Solution.
Hello
Please just follow recommendations of the Hardware Development Guide :
no need for termination of the mentioned signals.
Yuri
Hello
Yuri
Hi, Yuri
Thank you for your advice.
We will consider countermeasures against noise when not in use.
Very Thanks.
- satoshi
