Dear all,
I understand that Encode function of H.264 is 1920x1080@30fps at 266MHz.
Can VPU encode 2500x1500@15fps with H.264?
I calculate VPU performance as follows.
Is my understanding correct?
- 1920x1080@30fps=> 1920x1080x30=62,208,000
- 2500x1500@15fps=> 2500x1500x15=56,250,000
Therefore I think that VPU can support 2500x1500@15fps.
Would you please tell me some advice?
Yuuki
Solved! Go to Solution.
Hi Yuuki
I believe your calculations are correct and seems
this could be supported by vpu, however I am not aware of
similar tests.
Hi Yuuki
similar tests.
