Dear Sir or Madam,
Hello.
Now, my customer built the Yocto linux (L3.10.17) with graphical back end as x11.
But, they faced the tearing issue by using EGL.
I found below discussion.
[Q1]
Is my understanding right?
"X11 EGL has VSYNC issue = Can't prevent the Tearing"
(Or, this issue had already fixed?)
[Q2]
Which graphical back end should one select with using EGL?
Keita
Solved! Go to Solution.
Hi Keita
1. right, refer to attached document sect.1.7 Tearing
https://bugzilla.yoctoproject.org/show_bug.cgi?id=6760
2. wayland
Hi Keita
2. wayland
