About EIM read access timing in i.MX6DQ.
ソリューションへジャンプ
1,093件の閲覧回数
keitanagashima
Senior Contributor I
Hi All,
[Case]
The i.MX6 reads the data from external FPGA via EIM bus.
[Question]
When the FPGA outputs the WAIT & DATA signals to i.MX6, must the FPGA output the signals with the falling edge of EIM_BCLK from i.MX6?
(Because i.MX6 latches the WAIT & DATA signals with rising edge of EIM_BCLK.)
Keita
ラベル(3)
986件の閲覧回数
Yuri
  Basically, any of previous clock edges may be used (rising, falling) ;
depending on internal FPGA delays.
Yuri
987件の閲覧回数
Yuri
Yuri
