About DQ amplitude by DDR3 stress test in i.MX6DQ.
1,015 次查看
keitanagashima
Senior Contributor I
Dear All,
Hello. We found the 1st bit of the DQ amplitude was small by DDR3 stress test (Writing mode).
And, tDS/tDQ found tight specifications (DQS or DQ - CLK).
*Refer to attached file.
How to increase the DQ amplitude?
For example, if user increase the DQ Drive strength (40 Ohm --> 34Ohm), is this issue improved?
This question is related to the following thread.
https://community.freescale.com/message/558926#558926
Keita
标签 (2)
862 次查看
Yuri
Yes, the DQ amplitude may be improved by increasing the drive strength.
Yuri.
862 次查看
Yuri
  Please refer to reply from app team in
About Signal amplitude on DQ lines in i.MX6DQ.
Yuri
862 次查看
keitanagashima
Dear Yuri,
Hello. Thank you for your reply.
I think so, too.
The amplitude was improved by ODT setting.
Another way, the DQ amplitude was improved by increasing the drive strength, isn't it?
Keita
863 次查看
Yuri
Yuri.
