Hello community,
I hope to know a 24 MHz oscillator tolerance of i.MX6ULL.
I can find out it in Table 17 of IMX6ULLHDG.
If both ether and USB (and any other external condition) not considered,
which value will be a tolerance of i.MX6ULL device required?
Ishii.
Solved! Go to Solution.
Hello Ishii,
If you will not be using Ethernet it is recommended to use an oscillator with +- 150ppm tolerance, even if you won’t be using the USB module, as these are the tested configurations.
I hope this helps!
Hello Ishii,
I hope this helps!
Hello gusarambula,
Thank you for your response.
I will answer it to my customer.
Ishii.
