ATF support for SDEI on imx8qm
985 次查看
Matteo_Zini
Good afternoon,
I wanted to ask whether the Arm Trusted Firmware (ATF) had support for the Software Delegated Exception Interface (SDEI) on imx8qm.
When trying to build ATF with the SDEI_SUPPORT=1 and EL3_EXCEPTION_HANDLING=1 options, I get some errors from the compiler ('PLAT_SDEI_SGI_PRIVATE' and 'PLAT_SDEI_NORMAL_PRI'  undeclared).
Thank you in advance
Matteo Zini
标记 (2)
968 次查看
Harvey021
Hi @Matteo_Zini
Didn't build ATF with these options, would suggest you check their source code of ATF and documents for details. sorry can't really help u for this.
Harvey
