Hi All,
I am working on IMX8QM-MEK with Android Automotive. I have some doubt regarding power management.
1. Is it possible to sleep/ wake up the head unit using from M4 ?
2. Is M4 Core have the cloud support ?
Thank You,
Vinoth S,
Solution here,
IMX8QM-MEK Power Management difference between Linux and Android
VinothS.
you may need to configure the M4's MU as a wakeup source for A core. And has simulate the power key event and send to A core.
Could you give a more detail description about your case? We may think how to add into our release.
Hi chenguoyin
I able to put on deep sleep by using
AP_POWER_STATE_REQ - 4, 2
Configure the timer for some of the min
And exit from Deep Sleep
AP_POWER_STATE_REQ - 3,2
Vinoth S,
Thank You chenguoyin for the quick reply.
How to configure M4 is WakeUp source for A core ?
Will you please provide the configuration.
Able to suspend and wakeup by using this commands,
AP_POWER_STATE_REQ - adb shell dumpsys activity service com.android.car inject-vhal-event 0x11410a00 4,2
Reference Link,
Power Management | Android Open Source Project
I have to configure user wakeup the system instead of internal timer. AP_POWER_STATE_REQ using rtc timer to wakeup the system.
Thanks & Regards,
Vinoth S,
Thank you Victor Linnik for the quick reply.
How to configure user to control the sleep and wakeup by Ethernet ?
by using mem - able to sleep and wakeup the system.
Is there any configuration USER to control the sleep and wakeup functionality from M4 ?
Thanks & Regards,
Vinoth S,
Is there any documents/ reference for Power Management using ARM Cortex-M4 core ?
Vinoth S,
Is anyone experience with M4 give some ideas ?
Thanks & Regards,
Vinoth S,
