Dear community.
Our customer has question below.
Regarding the APBH register, since it is booting with NOR FLASH in the customer system, is there no doubt that this register is not set?
Thank you,
Best Regards.
T.Takahashi.
Solved! Go to Solution.
Hi Takahashi
APBH is used with nand as shown on Figure 14-1. AHB-to-APBH Bridge DMA Block Diagram
i.MX6DQ Reference Manual so ROM initializes it only for nand boot.
http://cache.nxp.com/files/soft_dev_tools/doc/support_info/iMX6DQPRM.pdf
Hi Takahashi
