AOSP build failed :Android 11 with imx8qxpC0
2,056 次查看
jackey267
hello NXP :
1 another try to build AOSP (Android 11)has been failed:
2 the follow was the error log file for your reference:
3  failed at location:
[ 99% 136548/137181] Target Java: out/target/common/obj/APPS/Dialer_intermediates/classes-full-debug.jar
FAILED: out/target/common/obj/APPS/Dialer_intermediates/classes-full-debug.jar
4  more detailed please decompress the zip log file to see it .
5 hope to hear from you !
6 thank you for your help.
7 ubuntu20.04.3 LTS +Intel(R) Core(TM) i7-10700 CPU @ 2.90GHz 16Ghz +MemTotal: 16169652 kB
8 cmd  :
$source ~/imx-android-11.0.0_2.2.0/imx_android_setup.sh
$cd ~/tools
$git clone https://android.googlesource.com/platform/prebuilts/clang/host/linux-x86  prebuilt-android-clang -b master
$export CLANG_PATH=/home/zsh/tools/prebuilt-android-clang
$export AARCH64_GCC_CROSS_COMPILE=/opt/gcc-arm-8.3-2019.03-x86_64-aarch64-elf/bin/aarch64-elf-
:~/android_build$ source build/envsetup.sh
:~/android_build$ lunch mek_8q-eng
$./imx-make.sh -j16 2>&1 | tee build-log.txt
9 yesterday night it was failed one more time .build-log_4.zip thanks .10.25th,9:19am shenzhen china .thanks .
2,034 次查看
Zhiming_Liu
11_2.2 doesn't support qxp,android111_1.0.0 is lastest version for qxp
2 Supported Hardware SoC/Boards
The supported hardware system-on-chip (SoCs)/boards are listed as follows:
• i.MX 8M Mini EVK
Supported daughter boards:
— With DDR4 RAM, Rohm bd71847 PMIC chip and Cypress CYW43455 Wi-Fi/Bluetooth module
— With LPDDR4 RAM, NXP pca9450 PMIC chip and NXP 88W8987 Wi-Fi/BT module.
Supported mother board:
— Rev. C mother board
• i.MX 8M Nano EVK
— With LPDDR4 RAM, NXP pca9450 PMIC chip and NXP 88W8987 Wi-Fi/Bluetooth module
• i.MX 8M Plus (Silicon Revision A1) EVK Board and Platform
• i.MX 8M Quad EVK Rev. A Board and Platform
