AN4199 Rev 1, wrong figure on page 8
1,647 次查看
lategoodbye
Senior Contributor I
In the application note "Using the i.MX28 Power Management Unit and Battery Charger" on page 8 the figure 4 should show the enable logic of the linear regulators.
Unfortunatelly it shows the automatic battery update, the same figure like on page 11.
I think the right one would be something like in AN3883 "i.MX233 Power Management Unit and Battery Charger" on page 11.
标记 (2)
1,503 次查看
igorpadykov
Hi Stefan
yes you are right, previous revision (attached) has correct picture.
1,504 次查看
igorpadykov
Hi Stefan
