Hello
Hope you are doing well!
I have connected i.MX8M NANO EVK to the 10.5 inch AMOLED display and the display is not able to run the application which is running successfully when connected to monitor/desktop and there is this "failed to start terminate psplash-quit.service" error observed in the ssh terminal, attached image FYR. Please do guide me for what is this error coming and also steps to resolve the error.
iMX8MNANO
The "failed to start terminate psplash-quite service" error usually occurs when there is an issue with the graphical display service on the i.MX8M NANO EVK board Asphalt 9 mod apk....
