AC3 file playback with Jellybean Freescale Firmware
1,644 次查看
saurabh206
Senior Contributor III
I could not able to play Video file with AC3 audio.
I/OMXPlayer( 2294): failed to open file: /data/system/audio_pass_through_pref.
I/OMXPlayer( 2294): Can't open library: lib_ac3d_wrap_arm11_elinux_android.so
I/OMXPlayer( 2294): Cannot load library: load_library(linker.cpp:745): library "lib_ac3d_wrap_arm11_elinux_android.so" not found
How can I get lib_ac3d_wrap_arm11_elinux_android.so?
Saurabh
标记 (3)
1 回复
1,143 次查看
mingzhou
Hi:
     do you have the codec excluded package for ac3 library?
     if not, you will not get the package until you get Dolby's license.
Mike,
