A solution CS toggling in ecspi(case CM4)
1,311件の閲覧回数
gabper3x
Dear community,
https://community.nxp.com/t5/i-MX-Processors/Chip-Select-Toggling-Between-Bytes/m-p/1579621
Just I have faced this issue in CM4.
The best solution is handling GPIO individually also CM4 after all?
3 返答(返信)
1,293件の閲覧回数
joanxie
this solution is for A core, if you need use this for M core, you need disable in the dts file firstly
1,268件の閲覧回数
gabper3x
I wanted to know a way how to fix the issue SS can't stay low during transmitting.
I think I can't clear it completely.
So the best solution is separating and controlling individually SS as a GPIO.
1,234件の閲覧回数
joanxie
what processor do you use? imx6q or imx8qm?
