Hi peng
from log: "i.MX6Q-SabreSD and Boot Device :SPI NOR" seems
reason may be that spi-nor boot is not supported for SabreSD,
but supported for Sabre AI boards. One can try to rebuild images
(mfg tools firmware and linux) based on Sabre AI board configuration,
and reuse profile "MX6Q-Sabreauto-SPI_NOR & SD card" in ucl2.xml
But the MFGTools's cfg.ini is:
the Board was made by ourself according to i.MX6Q-SDB of freescale.
what is the meaning "Boot Device :SPI NOR" from your log ?
For that,I don't kown why the Boot Device is SPI NOR ,but I think it should be:Boot Device: MMC
I think you can check boot settings for that.
Thank you !how to check it ?
