I'm using demo image For test, linux versions:L5.15.71_2.2.0, this problem occurs that "Failed to start Weston". Please help with some suggestions.thanks.
Solved! Go to Solution.
demo images from nxp official website,but I replaced the Monitor (HDMI),issue has been settled. Thanks
how about restarting weston when your board boot up?
I've tried restarting weston, still doesn't solve the problem. I found the same problem with the new EVK. It doesn't seem to be a hardware problem, use Default image (L5.15.71_2.2.0_MX8MM), Is this a general question?
what image do you use? demo images from nxp official website or you own customized image?
