Hello, I will be using 88W8987 for my custom board and I know that this module is used with i.MX8MN EVB. But for the device tree of i.MX8MN EVB, I did not see any info regarding to this module also how can I see the pins that is used on the linux driver for this module? As far as I know the source firmware is at my yocto build directory under the folder mxm_wifiex/wlan_src/mlinux/?
What can I do to adapt this module for my board? What kind of path should I follow?
Thank you in advance.
Hi @Wobaffet,
