7ULP power_mode_switch not building with IAR
4,594 次查看
GuillaumeAudirac
I downloaded the EVK SDK for the i.MX7ULP (SDK_2.7.0_EVK-MCIMX7ULP.zip). I currently build the power_mode_switch example with cmake as it seems to fail when using IAR.
Do you know any reason for that?
I am using the IAR IDE 8.11.1.13272 and it fails on some preprocessing error directives:
#error intrinsics.h is already included previously!
Is this just an issue with the SDK package?
Thanks.
Guillaume Audirac
标记 (1)
4,488 次查看
Hi Guillaume
reason may be old IAR version as described in Release Notes,
I tried with IAR 8.20 it builds fine
4,489 次查看
Hi Guillaume
4,488 次查看
GuillaumeAudirac
You are absolutely right. I had not checked as it was working fine for other examples.
Thanks a lot!
Guillaume Audirac
