4G is not reserve or alternate of WiFi
Search instead for
vinothkumars
Senior Contributor III
Dear NXP,
I am working Android 7 on imx6 processor,  I want to make 4G should be used for telematic only. I want set up some restrictions to use telematic server only.
For any other purposes: no WiFi – no internet (do not use 4G). Special case is hotspot on the device. In this case I should not share 4G internet to user.
I need some fix. If it possible please provide the MQTT commands to avoid sharing the 4G network to user
Thanks & Regards,
VinothS
Vinothkumar Sekar
Labels (3)
gusarambula
Hello VinothS,
I would recommend reaching to the Google Developer forums as we do not have documentation covering this topic. My apologies for the inconvenience.
vinothkumars
This configuration is done in firmware side,  I closed this thread now.
VinothS
Vinothkumar Sekar
vinothkumars
Thank you Gusarambula for your reply.
Vinothkumar Sekar
