2 SDIO ports on IMX233
1,542 次查看
kamejoko80
Is it possible to configure 2 SDIO ports at them same time on IMX233  ?
I need to use them for microSD and 88W8686 based SDIO card module.
IMX233 doesn't support SPI 16bit data mode, so I coudn't configure the libertas wifi driver by using GSPI interface.
Thanks and best regards.
标签 (1)
1 回复
884 次查看
phuongdangminh
OK,
After some time of modifing and testing, switching between sadness and happiness and pulling my hair out, I finally got my custome board work with two SDIO ports support.
Here is the job:
linux-2.6.35.3/arch/arm/mach-mx23/device.c
#if defined(CONFIG_MMC_MXS) || defined(CONFIG_MMC_MXS_MODULE)
#if !defined(CONFIG_SPI_MXS) && !defined(CONFIG_SPI_MXS_MODULE)
#if defined(CONFIG_MMC_ON_SSP1)
/* mmc0 platform data */
static struct mxs_mmc_platform_data mx23_mmc0_data = {
  .hw_init = mxs_mmc_hw_init_mmc0,
  .hw_release = mxs_mmc_hw_release_mmc0,
  .get_wp = mxs_mmc_get_wp_mmc0,
  .cmd_pullup = mxs_mmc_cmd_pullup_mmc0,
  Don't change ssp clock because ssp1 and ssp2 share one ssp clock source
  ssp module have own divider.
  .setclock = mxs_mmc_setclock_mmc0,
  .caps = MMC_CAP_4_BIT_DATA,
  .min_clk = 400000,
  .max_clk = 48000000,
  .read_uA        = 50000,
  .write_uA       = 70000,
  .clock_mmc = "ssp.0",
  .power_mmc = NULL,
/* mmc0 resource */
static struct resource mx23_mmc0_resource[] = {
  .flags = IORESOURCE_MEM,
  .start = SSP1_PHYS_ADDR,
  .end = SSP1_PHYS_ADDR + 0x2000 - 1,
  .flags = IORESOURCE_DMA,
  .start = MXS_DMA_CHANNEL_AHB_APBH_SSP1,
  .end = MXS_DMA_CHANNEL_AHB_APBH_SSP1,
  .flags = IORESOURCE_IRQ,
  .start = IRQ_SSP1_DMA,
  .end = IRQ_SSP1_DMA,
  .start = IRQ_SSP_ERROR,
  .end = IRQ_SSP_ERROR,
static void __init mx23_init_mmc0(void)
  struct platform_device *pdev;
  pdev = mxs_get_device("mxs-mmc", 0);
  if (pdev == NULL || IS_ERR(pdev)) {
  printk ("mxs-mmc0 get device failed\n");
  return;
  pdev->resource = mx23_mmc0_resource;
  pdev->num_resources = ARRAY_SIZE(mx23_mmc0_resource);
  pdev->dev.platform_data = &mx23_mmc0_data;
  mxs_add_device(pdev, 2);
#else /* CONFIG_MMC_ON_SSP1*/
static void mx23_init_mmc0(void)
#endif /* CONFIG_MMC_ON_SSP1 */
#endif /* !defined(CONFIG_SPI_MXS) */
#if defined(CONFIG_MMC_ON_SSP2)
/* mmc1 platform data */
static struct mxs_mmc_platform_data mx23_mmc1_data = {
  .hw_init = mxs_mmc_hw_init_mmc1,
  .hw_release = mxs_mmc_hw_release_mmc1,
  .get_wp = mxs_mmc_get_wp_mmc1,
  .cmd_pullup = mxs_mmc_cmd_pullup_mmc1,
  .setclock = mxs_mmc_setclock_mmc1,
  .min_clk = 400000,
  .read_uA        = 50000,
  .write_uA       = 70000,
  .power_mmc = NULL,
/* mmc1 resource */
static struct resource mx23_mmc1_resource[] = {
  .start = SSP2_PHYS_ADDR,
  .end = SSP2_PHYS_ADDR + 0x2000 - 1,
  .start = MXS_DMA_CHANNEL_AHB_APBH_SSP2,
  .end = MXS_DMA_CHANNEL_AHB_APBH_SSP2,
  .start = IRQ_SSP2_DMA,
  .end = IRQ_SSP2_DMA,
static void __init mx23_init_mmc1(void)
  pdev = mxs_get_device("mxs-mmc", 1);
  printk ("mxs-mmc1 get device failed\n");
  return;
  pdev->resource = mx23_mmc1_resource;
  pdev->num_resources = ARRAY_SIZE(mx23_mmc1_resource);
  pdev->dev.platform_data = &mx23_mmc1_data;
#else  /* CONFIG_MMC_ON_SSP2 */
static void mx23_init_mmc1(void)
#endif /* CONFIG_MMC_ON_SSP2 */
#else /* defined(CONFIG_MMC_MXS) */
#endif /* defined(CONFIG_MMC_MXS) */
#if defined(CONFIG_SPI_MXS) || defined(CONFIG_SPI_MXS_MODULE)
CMDLINE_DEVICE_CHOOSE(ssp1, spi1, spi1)
#else
CMDLINE_DEVICE_CHOOSE(ssp1, mmc0, mmc0)
#endif
CMDLINE_DEVICE_CHOOSE(ssp2, mmc1, mmc1)
linux-2.6.35.3/arch/arm/mach-mx23/mx23evk_pins.c
static struct pin_desc mx23evk_mmc0_pins[] = {
  /* Configurations of SSP1 SD/MMC port pins */
  .name = "SSP1_DATA0",
  .id = PINID_SSP1_DATA0,
  .fun = PIN_FUN1,
  .strength = PAD_4MA,
  .voltage = PAD_3_3V,
  .drive = 1,
  .name = "SSP1_DATA1",
  .id = PINID_SSP1_DATA1,
  .fun = PIN_FUN1,
  .drive = 1,
  .name = "SSP1_DATA2",
  .id = PINID_SSP1_DATA2,
  .fun = PIN_FUN1,
  .drive = 1,
  .name = "SSP1_DATA3",
  .id = PINID_SSP1_DATA3,
  .fun = PIN_FUN1,
  .drive = 1,
  .name = "SSP1_CMD",
  .id = PINID_SSP1_CMD,
  .fun = PIN_FUN1,
  .drive = 1,
  .name = "SSP1_SCK",
  .id = PINID_SSP1_SCK,
  .fun = PIN_FUN1,
  .strength = PAD_8MA,
  .drive = 1,
static struct pin_desc mx23evk_mmc1_pins[] = {
  /* Configurations of SSP2 SD/MMC port pins */
  .name = "SSP2_DATA0",
  .id = PINID_SSP2_DATA0,
  .fun = PIN_FUN3,
  .pullup = 1,
  .drive = 1,
  .pull = 1,
  .name = "SSP2_DATA1",
  .id = PINID_SSP2_DATA1,
  .fun = PIN_FUN3,
  .pullup = 1,
  .drive = 1,
  .pull = 1,
  .name = "SSP2_DATA2",
  .id = PINID_SSP2_DATA2,
  .fun = PIN_FUN3,
  .pullup = 1,
  .drive = 1,
  .pull = 1,
  .name = "SSP2_DATA3",
  .id = PINID_SSP2_DATA3,
  .fun = PIN_FUN3,
  .pullup = 1,
  .drive = 1,
  .pull = 1,
  .name = "SSP2_CMD",
  .id = PINID_SSP2_CMD,
  .fun = PIN_FUN3,
  .pullup = 1,
  .drive = 1,
  .pull = 1,
  .name = "SSP2_SCK",
  .id = PINID_SSP2_SCK,
  .fun = PIN_FUN3,
  .pullup = 0,
  .drive = 1,
  .pull = 0,
#endif /* CONFIG_MMC_MXS */
linux-2.6.35.3/drivers/mmc/host/Kconfig
config MMC_ON_SSP1
  tristate "MMC0 on SSP1"
  depends on MMC_MXS && MACH_MX23EVK
  help
  Select Y to enable MMC0 on SSP1.
config MMC_ON_SSP2
  tristate "MMC1 on SSP2"
  help
  Select Y to enable MMC0 on SSP2.
