【1】How to connect the AUDMUX port with a voice codec and the PCM port of Bluetooth simultaneously?
1,161 次查看
johnphy
     We are using I.MX6Q, and we connect the AUDMUX  port  with the  voice codec chip  WM8962B. Now we also need  to use the PCM audio function of  the bluetooth module. So can anybody help to give some advice? Can we connect the AUDMUX  port with a voice codec and the PCM port of Bluetooth simultaneously?
    Thanks a lot!
914 次查看
alejandrolozan1
Would you be nice enough to share the part number of the devices you want to connect?
Alejandro
