關於mini pcie上插上WIFI+BT的module 無法install的問題
陳冠儒
hi,all
小弟,今天又有一個新的問題想請教大家,是關於我再版子上(i.mx6q)插上一塊mini pcie的wifi+bt的module(群光出的C706E0-A2 combo module),但我利用SD卡開機後將driver整個目錄copy到sd卡上,利用./install.sh去install他,但他會出現如下訊息:
(紅字部分有錯)
uthentication requested [root] for make clean:
cd hal/OUTSRC/ ; rm -fr */*.mod.c */*.mod */*.o */.*.cmd */*.ko
cd hal/OUTSRC/ ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd hal/led ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd hal ; rm -fr */*/*.mod.c */*/*.mod */*/*.o */*/.*.cmd */*/*.ko
cd hal ; rm -fr */*.mod.c */*.mod */*.o */.*.cmd */*.ko
cd hal ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd core/efuse ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd core ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd os_dep/linux ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd os_dep ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
cd platform ; rm -fr *.mod.c *.mod *.o .*.cmd *.ko
rm -fr Module.symvers ; rm -fr Module.markers ; rm -fr modules.order
rm -fr *.mod.c *.mod *.o .*.cmd *.ko *~
rm -fr .tmp_versions
Authentication requested [root] for make driver:
make ARCH=armv7l CROSS_COMPILE= -C /lib/modules/3.10.53-1.1.0_ga+g496fbe0/build M=/media/mmcblk2p1/RTL8821AE_Linux_v4.3.8_12341_BTCOEX20140306-4b50.20141022/driver/rtl8821AE_linux_v4.3.8_12341.20141022_BTCOEX20140306-4b50  modules
make[1]: *** /lib/modules/3.10.53-1.1.0_ga+g496fbe0/build: No such file or directory.  Stop.
Makefile:1455: recipe for target 'modules' failed
make: *** [modules] Error 2
Compile make driver error: 2
Please check error Mesg
請問這是我少了什麼東西導致的嗎?我該如何安裝正確呢?
再麻煩各位幫忙一下了,感謝大家,謝謝。
Hi 陳 冠儒
according to log: /lib/modules/3.10.53-1.1.0_ga g496fbe0 ..No such file or directory
so I think one can look at script install.sh and check
folder paths which included in script, then correct them if necessary.
Hi 陳 冠儒
陳冠儒
hi,igorpadykov:
感謝您的回答,但我看不出來是哪裡的問題,我貼上去install.sh的全部內容,再麻煩您看看大概是哪裡的問題,我該怎麼改呢?謝謝。
install.sh內容:
#!/bin/bash
# Auto install for 8192cu
# September, 1 2010 v1.0.0, willisTang
# Add make_drv to select chip type
# Novembor, 21 2011 v1.1.0, Jeff Hung
echo "##################################################"
echo "Realtek Wi-Fi driver Auto installation script"
echo "Novembor, 21 2011 v1.1.0"
#   Decompress the driver source tal ball
cd driver
Drvfoulder=`ls |grep .tar.gz`
echo "Decompress the driver source tar ball:"
echo " "$Drvfoulder
tar zxvf $Drvfoulder
Drvfoulder=`ls |grep -iv '.tar.gz'`
echo "$Drvfoulder"
cd  $Drvfoulder
#   If makd_drv exixt, execute it to select chip type
if [ -e ./make_drv ]; then
./make_drv
fi
#                       make clean
echo "Authentication requested [root] for make clean:"
if [ "`uname -r |grep fc`" == " " ]; then
        sudo su -c "make clean"; Error=$?
else
fi
#   Compile the driver
echo "Authentication requested [root] for make driver:"
sudo su -c make; Error=$?
else
fi
#   Check whether or not the driver compilation is done
module=`ls |grep -i 'ko'`
if [ "$Error" != 0 ];then
echo "Compile make driver error: $Error"
echo "Please check error Mesg"
exit
else
echo "Compile make driver ok!!"
fi
echo "Authentication requested [root] for remove driver:"
sudo su -c "rmmod $module"
echo "Authentication requested [root] for insert driver:"
sudo su -c "insmod $module"
echo "Authentication requested [root] for install driver:"
sudo su -c "make install"
else
fi
echo "The Setup Script is completed !"
