执行出现错误 ./mxc_vpu_test.out -E "-w 176 -h 144 -f 0 -o enc.m4v"
Search instead for
画梁佳
[INFO]Product Info: i.MX6Q/D/S
[INFO]VPU firmware version: 2.3.10_r40778
[INFO]VPU library version: 5.4.16
[INFO]Format: STD_MPEG4
[INFO]MPEG4 class: MPEG4
[INFO]Output file "enc.m4v" opened.
[INFO]Capture/Encode fps will be 30
[INFO]chromaInterleave 1, mapType 0, linear2TiledEnable 0
ov3640_write_reg:write reg error:reg=3012,val=80
[INFO]sensor chip is ov5640_camera
Not support the resolution in camera
麻烦大师帮我看看,应该怎么解决。
joanxie
for your new camera, did you build in the bsp? if not, pls build this camera in the bsp first
joanxie
did you use ov3640?
pls try to use two commands before use unit test
modprobe mxc_v4l_capture
modprobe ov3640_camera
画梁佳
你好,我使用的是usb摄像头。
