记得以前Android4.2.2,可以通过如下命令获得mfgtool下的u-boot:
make distclean
make mx6dl_sabresd_mfg_config
make
但是从Android5.1开始,这些命令似乎不再适用了。
请问如何自己生成mfgtool下的 \Profiles\Linux\OS Firmware\firmware\u-boot-imx6dlsabresd_sd.imx?
解決済! 解決策の投稿を見る。
Hi jiang shao,
You can use the u-boot you build for your board, and in the newest BSP, mfgtool can use the same u-boot with the normal u-boot for your board. You do not need to build the u-boot for mfgtool separately. They can use the same one.
也就是说MFG Tools用的U-BOOT和正常工作用的,是一个U-BOOT,不用再另外编译了。你这里可以使用同一个u-boot。你试一下,有问题我们再沟通哈
Have a nice day
Dan
Note: If this post answers your question, please click the Mark Correct button. Thank you!
我参考了mfgtool的文档 Manufacturing Tool V2 Linux or Android Firmware Development Guide V2.docx
里面有这样的描述:
How to Generate U-Boot and Kernel Image for MFG
Please refer to the BSP User Guide, chapter Build Manufacturing Firmware.
这个BSP User Guide是指 Android_User's_Guide.pdf 吗?
但是我在 Android_User's_Guide.pdf 中没有找到有关Build Manufacturing Firmware的章节
希望有FAE能给与支持
Hi jiang shao,
Have a nice day
Dan
Hi jiang shao,
For how to build the Manufacturing Firmware on Android5.1, I will confirm it for you. Please wait.
Have a nice day
Dan
