如何将git上的内核代码写入bb脚本中来让其用bitbake自动下载并编译,我尝试之后出现:
1,366 次查看
zhezhang1
ERROR: linux-imx-4.1.15-r0 do_copy_defconfig: Function failed: do_copy_defconfig (log file is located at /home/zhangzhe/fsl-release-bsp-L4.1.15/build-x11/tmp/work/imx6qsabresd-poky-linux-gnueabi/linux-imx/4.1.15-r0/temp/log.do_copy_defconfig.17522)
ERROR: Logfile of failure stored in: /home/zhangzhe/fsl-release-bsp-L4.1.15/build-x11/tmp/work/imx6qsabresd-poky-linux-gnueabi/linux-imx/4.1.15-r0/temp/log.do_copy_defconfig
ERROR: Task 6 (/home/zhangzhe/fsl-release-bsp-L4.1.15/sources/meta-fsl-bsp-release/imx/meta-bsp/recipes-kernel/linux/linux-imx_4.1.15.bb, do_copy_defconfig) failed with exit
1,061 次查看
jimmychan
could you show me the steps so I can reproduce the issue on my side?
1,061 次查看
zhezhang1
thank you,i got it。
在 2017-02-27 16:42:27,"jimmychan" <admin@community.nxp.com> 写道:
NXP Community
Re: 如何将git上的内核代码写入bb脚本中来让其用bitbake自动下载并编译,我尝试之后出现:
reply from jimmychan in i.MX Community - View the full discussion
Reply to this message by replying to this email, or go to the message on NXP Community
Start a new discussion in i.MX Community by email or at NXP Community
Following Re: 如何将git上的内核代码写入bb脚本中来让其用bitbake自动下载并编译,我尝试之后出现: in these streams: Inbox
This email was sent by NXP Community because you are a registered user.
You may unsubscribe instantly from NXP Community, or adjust email frequency in your email preferences
