在linux下,imx8qxp如何实现双屏异显
783435100
如题。谢谢!
joanxie
you can download 8qxp demo images from nxp official website, then download them to your board, as I known, you can use the default dtb  named Image-fsl-imx8qxp-mek.dtb, after board boot up, you can use the gstreamer command in my document to test
joanxie
maybe you can refer my another document for imx8mq:
https://community.nxp.com/t5/i-MX-Processors-Knowledge-Base/i-mx8M-EVK-board-encoder-and-decoder/ta-...
how to play the two different video to the different display
783435100
这个例子无从下手,有个简单代码就好,或者有个针对imx8qxp例子最好。
joanxie
