iMX6UL-VDD_ARM_SOC_IN-Overshoot_On_EVK
Voltage overshoot (>1.8V) is found on VDD_ARM_SSOC_IN when the EVK board is powered down by POWER BUTTON long pressed after the Linux kernal loaded. It would not happen if only U-boot is run. It happens also when the system recovers from idle. The overshoot is out of i.MX6UL maximum rating.
添付
評価なし
バージョン履歴
最終更新日:
‎02-24-2021 02:31 AM
更新者:
